Re: r/o system & water softener pressure
Posted by hj on November 03, 1999 at 20:08:06:
In response to Re: r/o system & water softener pressure
Yes, in fact 45 p.s.i. is almost too low for proper operation and sufficient water flow in the plumbing system.
: My r/o system is not working properly and I have read that in order to operate properly, the water pressure should be at least 60 psi. Looking at the gauges on my softening system I read 40-45 psi. Can I adjust to 60 psi without any negative effects to the softener system?
Replies to this post
There are none.
