Re: Water filter
Posted by Moore on October 31, 1999 at 00:55:20:
In response to Re: Water filter
Install the filter before the softener. Install it in a place where you will have good access to it for a while, so that you can clean it often. That way you will also protect the softener. You'll find out that after your filter does its job for the first three months, you'll be cleaning it less and less.
: I want to install a water filter for the 'whole' house. Do I install it before the softener or after? I have a
: rust, sediment,carbon and chlorine filter. Thanks
Replies to this post
There are none.
