| Posted by Bud..Suncoast Plumbing on October 26, 1999 at 06:44:12: | |
| In response to Re: Rocking Washer | |
Rick:--Your post didn't mention if this is a newly purchased washer. If so it it may be due to shipping braces that have not been removed. It may be due to improper leveling of the front legs of the equipment( the rear legs on most of the newer models are self leveling, but the front ones are manually adjusted. It is important that you resolve this issue, considerable damage to both equipment and home can be the result if not corrected. Call the manufacturer for specific instructions for that make and model if your are not able to get a handle on the problem.......Lots of luck...Bud We have a large capacity washing machine that is nearly impossible to get a balanced load in. We've had someone out twice to look at it and they never seem to find anything wrong. : At some point during almost every load it begins to just about shake itself to pieces and beat against the wall. Any ideas?
| There are none. |
