Re: Can anybody help solve my washing machine problem
Posted by Curt on October 25, 1999 at 16:24:39:
In response to Re: Can anybody help solve my washing machine problem
: Hello--I am having trouble with my washer. It takes a lifetime to fill the tub with water. Husband has taken hose out of the back, and cleaned out a filter type object. This will help for a month or so, and then we are back to square one. Any ideas on how this can be fixed---permanently! Thank you. My washer has the same problem. Actually the problem is with the amount of grit in the water, which is trapped at the screen inside the hose connection of the water. The cold water inlet is the culprit, the grit in the hot water is left in the bottom of the water heater. You could add a sediment filter to your incoming water, either on the whole house or just prior to the washer. You would need to change this filter periodically as well.
Replies to this post
There are none. |
