Whirlpool Pump not working
Posted by Dennis on October 25, 1999 at 12:19:36:
My whirlpool pump doesn't turn on when I use the switch. How can I go about determining if it is the switch or the pump that is the problem? Is this a job best suited for a plumber or electrician. I have access to the pump through an access panel but the switch is at the other end of the tub. If it is the switch, can it be replaced without creating another access point at that end of the tub. Thanks in advance for your help.
Replies to this post
There are none. |
