Re: Bad tasting water - RESOLUTION
Posted by Dave on October 22, 1999 at 19:43:00:
In response to Re: Bad tasting water - RESOLUTION
We figured out what the problem was, with the help of a guy from the City water department (image that!). It turns out that I had a hose outside that had the spicket turned on, but it had a sprayer on the other end. So, the water was backing up into the house, after being in the hose. Disconnecting the hose from the house, and letting the water flush for awhile seems to have done the trick. Thanks for your suggestions.
Replies to this post
There are none.
