Re: Water Still Leaks From The Stem
Posted by Terry Love on June 15, 1998 at 10:13:07:
In response to Re: Water Still Leaks From The Stem
 Josh, If water is leaking from the stem, you can try replacing the bonnet packing. that would be found behind the bonnet nut on the stem. I am assuming that the water is leaking past the packing on the stem. Sometimes you can tighten just a bit and get the leak to stop. Terry
Replies to this post
There are none. |
