| Posted by hj on October 21, 1999 at 08:12:53: | |
| In response to Re: water supply pressure regulator vavle | |
I assume the valve has given its maximum service. It will be easier, and maybe cheaper, to replace it, rather than try to find parts. And, no, it is not normal to spray water. : This morning my pressure valve was spraying water out a small hole on the side. It looked like it had been leaking all night. I have lived at this house for 7 years and this has never happened. I turned off the main supply. Do I need a new valve or can this be repaired or is this normal and sould I just let it spray? I look forward to you advice : Brett
| There are none. |
