Re: cutting cultured marble
Posted by pete on October 20, 1999 at 14:32:36:
In response to Re: cutting cultured marble
: You want a fine sabre saw or circular saw blade. Cutting from the back side or using a reverse cutting blade is the best way to avoid chipping the materiao. Carbide will melt the plastic and gum up the blade.
: : I will be installing cultured marble in a bath/shower enclosers what is the best way to cut the marble to fit.Will a carbide blade work? The edges I cut will not be seen.Is a router better, are there any tricks to cutting...
Will a wood cutting drill bit work to drill holes for the shower head and valve?
Replies to this post
