Re: PVC Toilet Flange Uneven
Posted by Terry Love on October 15, 1999 at 02:39:06:
In response to Re: PVC Toilet Flange Uneven
 : Dear Mr Love: : I recently removed a basement toilet that was leaking (badly) from beneath the base. : The flange (PVC) had not been glued to the PVC waste drain and the waste drain had a crack at the top. : I assumed that this was the leak. I epoxied the crack, and later test fit the flange. : When test fit, the flange is 3/4" higher on one side. Could this have been the leak? : Do I reinstall the toilet with one wax ring or two? : Should the wax ring be cut at an angle to compensate for the un-level flange? : The floor is level. The PVC waste drain is in concrete. : Could the crack at the top of the waste drain have been a result of the uneven flange? : Thanks for your help, this is a terrific website!!! : -Joe Thanks Joe, You will need enough wax to fill the void between flange and bowl. I like to see 1/2" or more of compression. Your unique situation may require some cutting and pasting so to speak, to ensure that the wax comes to level higher than the flooring. Terry
Replies to this post
There are none. |
