Re: ABS,PVC, VINYL (GENOVA) fittings, interchangeability
Posted by hj on October 12, 1999 at 09:15:17:
In response to Re: ABS,PVC, VINYL (GENOVA) fittings, interchangeability
Most codes either prohibit inteconnecting ABS andPVC, or if they allow it, only allow one traition at a connection and then the remainder of the system has to be of one material. If you do interconnect the materials, then you need special glue for it.
: In a residential drain system can I use ABS or GENOVA joints with PVC pipe? I have on hand a lot of older joints, but am also using some newer PVC joints and PVC pipe.
: Do codes allow/prohibit this practice? Is it technically a good/bad idea?
: Thanks,
: Ken Sapp
Replies to this post
