| Posted by hj on October 09, 1999 at 01:22:32: | |
| In response to Re: Toilet Tank Gasket | |
Did you use new bolt washers, and if so do you have metal washers between the bolt head and the washer? If so, remove them and everything will be okay. : I recently had to replace the sponge gasket between the tank and bowl. I reseated the tank several times, but it kept leaking. Finally I overtighted the tank and it broke. I have a new tank and new gasket, but again it continues to leak badly. What do I do? : Thanks, : Bob
| There are none. |
