| Posted by hj on October 08, 1999 at 02:39:36: | |
| In response to Re: Trouble removing Moen Cartridge 1222 | |
The tools that remove the 1200 brass core also work on the 1222, but you usually do not need them since the plastic ones normally pull out very easily. : Followed all the steps, but unable to pull out old Moen cartridge. I can turn it 360 degrees, but the cartridge refuses to come out. Called Moen customer service, told me to use hair spray or white vinegar to loose it up, anyone tried that? Moen tells me that there are no cartridge removal tools for Model #1222. : Thanks
| There are none. |
