Re: replacing cast iron main drain
Posted by Terry Love on October 07, 1999 at 13:51:09:
In response to Re: replacing cast iron main drain
 : I plan on replacing the main drain with plastic to make : a future bathroom addition easier to connect : whats the best way to disconnect the leaded connections : without using heat? I plan on using a no-hub connector : at the top but not at the floor, and dont want to break : the fitting and have to tear up the basement floor. : Thanks for any advice and tips, : Tom Tom, You can use a sawzall to cut the lead out of the joint, and then lift the pipe up. Fernco makes a rubber replacement seal that allows a new plastic pipe to be fitted into the hub. Terry
Replies to this post
There are none. |
