| Posted by hj on October 06, 1999 at 09:13:09: | |
| In response to Re: water heater leak | |
You can just replace the drain valve. The OEM ones almost always leak once they are used to drain the tank. : hi, just had my landlord's electric water heater repaired (upper element replaced) on friday. prior to this repair, there were no leaks.
| There are none. |
