: I live in a PA rancher which is on a concrete slab. Currently the clothes washer is in the kitchen and the dryer is in a utility room at the back of the house. I want to move them together, preferably into the utility room. The problem is drainage. The nearest existing drain line is in the kitchen which is approximately 15 feet away. What can I do? The home inspector we hired prior to the purchase told us that a pump to the nearest drain might work but would be expensive. Any ideas? Your washer has a pump that may do the job for you. Can you run the drain useing 3/4" pvc along the floor to the existing drain?Or is there a door to cross?I don't know how fancy you want this to look either.Good Luck on this.Dale Peck LMP
