Re: Ball Valves
Posted by hj on October 04, 1999 at 01:23:38:
In response to Re: Ball Valves
If it is rated with an AGA stamp, then most inspectors will okay it. If it is not stamped then the packing or tolerances may not be good enough to prevent gas leakage, even though they will hold water.
: Is it OK to use a regular full-port 1/2" ball valve (the kind used in water lines) in place of a 1/2" small T-handle gas ball valve? If not, what is the reason?
Replies to this post
There are none.
