| Posted by chris m on June 09, 1998 at 13:03:07: | |
| In response to Re: Drain vent | |
: Chris, : Using a three inch pipe for the tub is not the right thing to do. : Moving the vent closer to the tub waste would be the solution in this case. : Most tubs use an 1-1/2 trap and trap arm, the vent should be within 42". : Terry What size pipe should I use for the new vent pipe? To prevent a new hole in the roof I would like to branch the new vent to the old vent in the attic. What size pipe for the pipe connecting tub drain (5 feet away) to the house drain.? Thanks.....chris |
