Re: Gravity hot water central heating system
Posted by hj on September 26, 1999 at 20:01:57:
In response to Re: Gravity hot water central heating system
: Hi terry,
: I have recrently replaced my direct hot water cylinder with a indirect cylinder and re-made all the pipe connections to allow for a expansion tank and overflow pipe. The problem is the gravity hot water no longer reaches the tank from the boiler even though the pipe is 28mm?
: PS
: Can I add an additional pump on the return to boost the flow.
: Ta
Replies to this post
There are none.
