Re: replacement bowl
Posted by hj on September 23, 1999 at 01:08:02:
In response to Re: replacement bowl
If the holes line up, and most do not, then you shuld be able to use it. It will merely seem to flush several times before the water shuts off unless you use one of the new adjustable tank balls that can shut off faster.
: Can a new bowl from a 1.6 GPF be used with an older tank on an ELJER. I think the old tank is a 3.5 gallon. Will the new bowl handle the extra water? All the holes in the tank seem to match up.
Replies to this post
There are none.
