| Posted by Moore on September 19, 1999 at 23:49:21: | |
| In response to Re: shower lighting | |
: I need to install shower lighting which is waterproof. : I will be using the remodeling type of IC cans and I : will be used a sealed unit that I can mount next to : insulation. My question is which brand to use. I have a : choice of JUNO versus HALO. Anybody have any : experiences with these fixtures that you could share with me. : Many thanks. : Bob Both are good fixtures intended to be installed in moisture and vapor settings with insuulation around the can. Both come with excellent warrantees and customer backup. Install according to the directions in the packaging. Make sure the circuit they are wired to is protected with a ground fault interrupted at the source or at the sub-panel. |
| There are none. |
