shower water hammerring
Posted by Al on September 19, 1999 at 23:23:23:
All of a sudden the pipes in our tub/show start to hammer quite badly when the shower is on. I replace the diverter valve which corrected the hammerring problem (I think), but the flow coming from the tub spout was cut in about half as it use to be. From previous postings it sounds like a valve washer could be the problem which I will check. But if I put in what appeared to be a direct replacement for the diverter valve, why was the water flow cut in half? Thank you.
Replies to this post
There are none.
