| Posted by Terry Love on September 18, 1999 at 15:05:18: | |
| In response to Re: Thanks Terry and for old plumbing answer but job just got bigger.. | |
![]() hj must be a quicker plumber than I am. From the looks of the picture, it is going to be a bit tricky with the water lines so near. However, I think hj could do it. I've been reading his posts now for three years, and he does know his plumbing! By the way, nice picture Ronda. Terry : If only all your problems were so easy to fix. It just requires melting out the existing lead joint, and installing a new cast-iron closet bend. The hardest part is pouring the horizontal joint, which for a plumber is no problem at all. An hour, two at the most for a slow plumber, and a little bit of material. : : After we removed the subfloor we could see a crack in the pipe to the tolet. I guess it is time to call a
