| Posted by Jeff Houtz on September 17, 1999 at 09:32:58: | |
| In response to Re: fiberglass shower stall | |
I was concerned that the "threshold" is so low on those I've seen, that a curtain wouldn't be able to keep water in - what I thought I needed (or need) is a "threshold" that's higher than those I've seen -- getting the unit into the room may or may not be a problem -- J.
: : We need to replace a fiberglass pan & two-sided glass shower enclosure, and wish to put in a fiberglass unit (no larger than 42"square) - problem is that I can not find a one piece fiberglass unit that will accommodate a shower curtain (needs 'step in') - we don't want a glass door or side(s) like we have now -- any suggestions where to look for such a shower? : : Thanks! : : Jeff Houtz
| There are none. |
