| Posted by steve on September 14, 1999 at 01:48:54: | |
| In response to Re: Lake Water Pump Blows Line | |
: Just installed a sprinkler system in my lakefront property that works great until it shuts off. When it : shuts down the rubber coller I used to connect the pump inlet to the line to the lake ballons up then pops : off from the pressure. : Stats: install a check valve on the discharge side of the pump . This will prevent the head pressure from the sprinkler system to back up and overpressure your connection. OR you could put a valve in the discharge pipe and simply close the valve at the time you cut off the pump. Leave the check/foot valve on the suction side of pump so the pump will remain primed |
| There are none. |
