Re: Low flow problem - Please Help!
Posted by Tom Mathieu on September 07, 1999 at 18:01:08:
In response to Re: Low flow problem - Please Help!
I don't know how you can increase water pressure for the whole house, but to increase the flow of a showerhead, you could try this (it's probably illegal, but do what you want to do):
Some showerheads have the flow restrictor built into them so they can't be tampered with. However, there are some (generally the cheap ones) that have a small washer or metal plate with a hole in it that restricts the flow. If you remove the washer/plate or enlarge the hole using a drill bit, you should get higher pressure.
Good luck
Replies to this post
There are none.
