| Posted by Stu on September 03, 1999 at 19:27:10: | |
| In response to Re: Flapper dropping too soon causing incomplete flush | |
Thank you the quick response. The flapper is only a couple months old. I was wondering if I installed it incorrectly, or if instead my problem was being too cheap (buying the replacement kit in a home center chain store).
: : The flapper on my flush valve seems to drop prematurely, with several inches of water still in the tank, resulting in a short & incomplete flush. I've been told that this can be caused by having the chain too long, but adjustments to the chain length seem to have no effect. Is the flapper bad, or is there something else wrong?
| There are none. |
