| Posted by Curt on September 01, 1999 at 13:59:12: | |
| In response to Re: my Moen hotwater tub knob | |
: My hotwater tub knob is not turning far enough to turn off the hot water all the way. There is a steady stream of water from the tap so I had to turn it off at the source. I used to have to tuen the knob over and over to get it to go on it was almost like it was stripped. I can;'t afford to call anyone so any tips would be gratefully recieved. : Thanks Every manufacturer has a number of different types that have been around over the years, so I'm not sure even one of the pros (I'm not) could tell you what to do based on what you've written. You need enough mechanical ability to take it apart and recognize what is wrong. A replacement part is probably available at your local plumbing supply store. |
| There are none. |
