| Posted by Norm on August 19, 1999 at 22:31:49: | |
Terry, in your FAQ on jetted tub install you wrote the following My favorite method is to frame the tub support box to allow about an inch clearance under the bottom of the tub. Just before the tub is set into place, spread mortar mix on the floor. When the tub is set into place, it should be in full contact with the mortar for support. Putting some water in the tub will help to "hold" the tub into the mortar mix. Terry This may sound like a dumb question but I assume you mean mortar mixed with water or do you mean just the powder ??? |
| There are none. |
