| Posted by Randy Abby on August 17, 1999 at 23:51:41: | |
Currently have a tiled shower area that's pretty old (old mosaic tile) and grungy. Am interested in the 3-piece tub surrounds, however, have two questions: - First, on the exterior wall which would be where the center piece would be located, I currently have a standard double-hung window. I plan on replacing the old weathered window with glass block. Has there been any issues with stability or integrity of the surround after it has been cut to accommodate the window, and do you have any recommendation for trim at the glass block window edges? - Second, do I have to remove all the tile prior to securing the surround with adhesive or is there any special prepping required for the surround backing? |
