Re: Domestic hot water heater for radiant heat system
Posted by Lou on August 14, 1999 at 14:52:32:
In response to Re: Domestic hot water heater for radiant heat system
 First off I would go with the largest heater that you can fit in the space, 50 or 75gal. Because of your altitude you will loose a lot of btu's just because a simple lack of oxygen. The plumber who hooks up your gas and sets up your appliance to safely burn at that altitude will tell you that also. You must temper the water to use it to heat the slab, also keep the slab water seperate from the domestic hot water. The temperature of the slab water should be less than 110 degrees F, this will prevent hotspots on the slab. To do this we usually use a heat exchanger and two pumps. One pump circulates water through the heater and through the heat exchanger, the other pump circulates water through the slab, past an expansion tank (closed system requirement), into the bypass/heat exchanger piping arrangement. The bypass on the heat exchanger can be a fancy three way auto valve, but a ball valve works the best, as it does not need replacing every year like the other. On the type of water heater, I DUNNO! We use John Woods up here in Canada, why? because we have them to be compatible with the type of water we have in the area. Talk to your neighbours what kind do they have and how long has it lasted? Once you decide on a dependable brand that is available in your locale, very important as you don't want to have to be waiting for special order parts in winter, come back here, Terry has links to water heater manufacturers and I believe most if not all are now offering the energy efficient models with the pvc vent. I have a drawing I will post at the url below, just give me a minute or two.....Lou
