Re: whirpool leveling
Posted by hj on August 13, 1999 at 08:40:14:
In response to Re: whirpool leveling
Perfatape cement is usable, Also, spray foam will work if you put a piece of plastic between it and the tub so it does not cement the tub in place permanently.
: I am installing a Jacuzzi Cetra whirpool tub. It installs directly on the subfloor. The directions say that if the floor needs to be leveled to use a leveling compound, NOT mortar. What do they mean by a leveling compound or better yet what is the best and easiest way to get a level surface for this tub.
: Thanks
Replies to this post
There are none.
