| Posted by Tony on August 10, 1999 at 01:47:05: | |
| In response to Re: Cultured Marble Shower base & walls | |
: : : My first plan was to install a wet-bed tile shower floor base and Corian walls. I have been told that a pre-cast cultured marble base and sheets of cultured marble for the walls are just as good and half the price. Is this so? What would you recommend? : : I had a contractor who put in a cultured marble sheet at a base to the shower and the d@#n thing leaks every year. Other contractors have told me that the base should be a pan, not a flat sheet, with 4 to 5 inches up the sides. My advice: make sure, if you go cultured marble, that the base is a pan, not flat. : My understanding is that the Lehigh Cultured Marble Co. makes pre-cast cultured marble shower bases. The size that I am considering is 72 x 36. Does anyone have experience with this product? I thought that this type of base would be better than a fiberglass base that can flex with walking on it or crack if something heavy is dropped on it. Please advise. I am in stalling cultured marble panels for a shower (cultured marble pan) and a cast iron tub. I have replaced all the old drywall previously installed with moisture resistant 'greenboard'. Any tips on insalling the cultured marble panels? I have been told to use an epoxy in the corners, not caulk. Is this the preferred way? I was told caulk was OK to use around the bottom (between the panel and the tub or shower pan). |
| There are none. |
