Re: Toliet counter Ball breaking and results /solutions
Posted by Lou on August 07, 1999 at 12:17:59:
In response to Re: Toliet counter Ball breaking and results /solutions
Kevin:
Usually when the float ball breaks off, the excess water in the tank is exhausted through the overflow tube, into the bowl. Unless your overflow tube or bowl is plugged you should not have a flood. Maybe you had a defective float ball at the same time that the toilet or overflow tube was plugged?.....Lou
Replies to this post
There are none.
