Dear Terry, I am preparing to replace about 200' of rusty galvanized pipe which runs from a spring reservoir with a pump in it to a below frost line pressure tank in a small structure next to the house. The ground through which the pipe runs is fill with plenty of rocks. My water Ph is too low to use copper and I was wondering if there is any reason not to use PVC. I did hear from one plumber that if there is the slightest leak at a joint a tree root can clog the whole pipe. Have you ever heard of this happening? Also, do you know of any reason why I should not run the electric service to the pump (which I am also going to replace) next to the new pipe? Thanks, Barrie Mathason
