| Posted by hj on August 03, 1999 at 10:45:57: | |
| In response to Re: PEX VS. PVC | |
You do not want to use PVC inside the building. It will soften and break if you put hot water in it and the attic heat combined with the water and pressure can cause the cold water piping to break also. Either PEX or CPVC should be your plastic options. My preference, of the two, would be CPVC. : I NEED A REPIPE. I CURRENTLY HAVE SOMEONE COMING OUT IN TWO DAYS AND THEY ARE GOING TO USE VANGUARD PEX. IS THIS BETTER THAN PVC. EVERYONE IS TELLING ME SOMETHING DIFFERENT. PLEASE HELP
| There are none. |
