| Posted by Matt on August 02, 1999 at 20:37:23: | |
| In response to Re: Wall-hung toilet | |
What about a rear-outlet, floor-mounted toilet? (I learned about these from this web-site; thanks!) Since the outlet is 4" of so above the floor, this would maintain the height advantage, correct? Must the waste line turn downward immediately after the flange, or could it run horizontally from that point (with the required drop, of course)? Thanks for your help so far. Great site! - Matt : The carrier fitting required for a wallhung toilet is quite large and negates any height advantages. It also makes the wall much thicker. : : I'm finishing the upstairs of a 30 year old, : : - Matt
| There are none. |
