| Posted by j.wrigley on August 02, 1999 at 08:08:52: | |
| In response to Re: Epoxy grout? | |
: They are not that hard to work with, and are the only grouts I will use. This would be especially important in a high moisture environment. I have not seen a grout seal that does not have to be reapplied periodically, usually after mildew has begun. : : I asked before about mildew and 1/4" grout in a shower. HJ kindly replied that I would be OK if I used Kerapoxy. I have been asking around and have gotten different views. Some say that epoxy grouts are very hard to work with and not necessary, even for my application, and that if I properly seal, I can use non-epoxy grouts with confidence. : : Any help would be appreciated.
| There are none. |
