| Posted by hj on July 29, 1999 at 23:27:51: | |
| In response to Re: Pipe size and misc. questions... | |
2" drain branch line to the lavatory. 1/4" slope for 3" pipe. The vent connects to the top of the fixture fittings and rises to connect to the existing vent above the existing fixtures or goes through the roof. Toilet opening is 12" minimum from the wall. 3" drain for a toilet. 2" vent is sufficient. : What size PVC line do I run from a vanity (pedestal)sink? : I'm adding a full bath to my house. I discovered a 4" cleanout in my front yard, running down to the main drain, which eventually connects to the sewer line. I excavated around the cleanout and dug a ditch to my front porch where I had to cut a notch in the footing. Tapping into the cleanout, I laid the 3" PVC pipe up to the house yesterday and today I'm running the rest of it through the crawl space up to the bathroom. Several other questions... : Sloping 1/8" per foot of pipe for 3" PVC, right? : Does my vent have to connect to the 3" pipe "down stream" from the point where ALL drain line connect? Or can it be between two fixtures? Does a vent have to be 3" or can it be 2" PVC? : I have defined an interior bathroom wall I have yet to construct or errect. How far from the wall (stud) should I drill the toilet drain hole in the sub-floor? What about the tub drain? (I have not purchased my fixtures yet) : Is 2" PVC drain line sufficient for the toilet and tub drain? : Any responses are appreciated! : Thanks,
| There are none. |
