| Posted by Jerry Doyle on July 28, 1999 at 18:02:32: | |
We installed a Lennox complete heat system severy years ago. Because of many problems during that time, the Lennox company had the local contractor replace the main furnace and water heater unit several times (we have lost count). After the last installation, we noted a hammering noise when especially the hot water was turned off at a sink. Our heating contractor seemed to be of the opinion that it was not related to the furnace installation, but that probably the water pressure was too high. So we had a local plumber install a pressure reduction valve in the line to the house, since the pressure was originally about 100#. They turned it down to about 85#, the noise continued, I turned it down to about 55#. The noise continues. The same plumber installed a 3/4 inch Sioux water hammer arrester in the hot line from the water heater. It seemed to reduce the noise, but the sound seems to be telegraphing from another location. Prior to the arrestor installation, we installed a Laine hot water circulator at our utility room basin (all piping seemed to come from that first). As you can guess, we were confused by the fact that we were getting the noise at times when we were not turning on and off hot water.....finally coming to the realization that the circulating pump was also causing the noise when it completed its cycle.
