| Posted by Terry Love on July 28, 1999 at 18:00:16: | |
| In response to Re: Kohler Wellworth toilets | |
![]() : You are probably SOL. A 1993 Wellworth isn't like a 1999 model. It wasn't a very good 1.6 gallon toilet initially, and there's nothing magic that'll enhance the performance. Since the problem is "post-toilet," I'd tend to believe that any gravity 1.6 toilet would have this problem. A pressure-assisted one might not. : : I have 1993 models that don't clear paper from minimum slope sewer. Is there a way to modify to create greater volume or pressure or must they be replaced? If the problem is a plugging toilet, then replacement will do it. If your drainline is catching paper, by this I mean that the water is backing up the line and leaking around the base of the toilet, you may need a sewer line cleaning, or if that is clear, a toilet with more push, Pressure assist or Toto G-Max type. Terry
| There are none. |
