Re: Relocating waste drain lines through joists
Posted by Lou on July 28, 1999 at 12:06:30:
In response to Re: Relocating waste drain lines through joists
 The carpenters I work around prefer I don't drill 2" or 2 1/4" holes in a 2 x 8 floor joist. I can get away with one or two maybe, but they have to be close to the center of the joist, not in the top or bottom 25%. Usually doesn't leave much room for grade so I generally run them below the joists, next to the closest wall. Leaving a few extra cleanouts along the way, as needed. If I were you I would investigate this "grey water well",maybe it would be quicker, cheaper, faster just to increase the size of it and the pipe leading to it.....Lou
Replies to this post
There are none. |
