| Posted by paul somlo on July 27, 1999 at 14:39:00: | |
I am remodeling my bathroom and removed the leaded on brass flange to replace the flooring. Is there a flange available that does not need to be leaded on in this application? I have seen the type that slip inside and have four screws that cause a rubber gasket to flare, but am not sure if these can be used with lead as well as cast iron. |
