| Posted by hj on July 26, 1999 at 23:59:20: | |
| In response to Re: Rear Exit Toilets | |
I am perplexed by your statement that you do not have enough room for the pipe. Rear outlet toilets take a special fitting, and it always requires at least 2 to 3 inches between the riser pipe and the finished wall. This is in comparison to the conventional installation which allows the wall to be in contact with the riser pipe. : I am currently looking into installing a toilet in the attic of my house which I am remodeling. I am considering a rear exit toilet such as the Kohler K-4396 Anglesey, because I do not have enough rough in space from the finished wall to where the drain pipe has to run down to the basement. Do these rear exit toilets work as well as conventional toilets and is there any special piping that is required for these???
