| Posted by Dale's plumbing Service on July 25, 1999 at 13:07:37: | |
| In response to Re: leaking at bathroom sink trap | |
: We just moved intoi a new place and the traap under the bathroom sink is leaking at the top nut when the water runs hard. It seems as though the pipe going into the trap is loose, just sitting in there. There are no legs or other support on the front of the sink and it moves up and down maybe a half inch or so. Tried retightening the nut to no avail. Gary, you need to take the nut off and check to see if the tail piece is long enough inside the trap, also replace the washer. Dale Peck LMP |
| There are none. |
