Re: Cultured Marble Shower base & walls
Posted by Doreen on July 19, 1999 at 21:19:55:
In response to Re: Cultured Marble Shower base & walls
: My first plan was to install a wet-bed tile shower floor base and Corian walls. I have been told that a pre-cast cultured marble base and sheets of cultured marble for the walls are just as good and half the price. Is this so? What would you recommend?
I had a contractor who put in a cultured marble sheet at a base to the shower and the d@#n thing leaks every year. Other contractors have told me that the base should be a pan, not a flat sheet, with 4 to 5 inches up the sides. My advice: make sure, if you go cultured marble, that the base is a pan, not flat.
Replies to this post
