| Posted by Tammy on July 19, 1999 at 09:24:59: | |
Help! We have spent all weekend trying to find out what is causing our leak. You can see the water trinkling into the toilet bowl so we replaced the flapper. It is still leaking. We cut off the water and it appears to leak about 1 - 2 inches below the water line and then stops. We turned the water back on and it does nothing. Sometimes it will automatically refill and other times it won't. But it only leaks about a couple of inches and then stops. |
