| Posted by Lou on July 17, 1999 at 01:47:18: | |
| In response to Re: No hot water pressure.Cold water is fine | |
![]() Turn off your water and remove your hot cartridge. Turn water back on to flush out any debris in the hot line. Then install new cartridge and seat in hot side of tapset. Since you will have the water off it won't hurt to check out the cold side also. Hope this helps.....Lou |
| There are none. |
