Re: Hot Water Solution
Posted by Lou on July 17, 1999 at 01:42:57:
In response to Re: Hot Water Solution
Plumb in two 40 gal, gas water heaters. Pipe them
in a series/parallel manner, link is below, and
set temp on first one lower than second and you
should be fine. Also since you are building new
ask about a hot water recirc system, most of the
small domestic systems I do will set up a natural
convection current and work without a pump.....Lou
Replies to this post
There are none.
