| Posted by Dennis on July 16, 1999 at 23:11:38: | |
| In response to Re: relocating washer plumbing | |
: : In a single story home, is it possible to move the plumbing for a washer : : to another room and use the existing pipes? : Yes, you can move the hookup for the washer to another room using the existing pipes. Without seeing the job, it is hard to say exactly how easy it would be. Remember, "All things are possible, some things just take more time and money" Terry : Thank you. I think the main thing I was needing to know would have to do with the drain itself. At it's current location it, like most washer drains, goes straight down into the ground..but, I can still use the existing drain? |
| There are none. |
